Formatting Hard Drive for secondary drive without losing recovery partition
DFL
4
Title sums it up pretty much, I want to use one of my old hard drives as a storage/large program installation drive in my computer. So I need to wipe the main partition and what not. Question is, can I simply go into my Disk Manager and format it as NTFS to use for installations etc while leaving the recovery partition intact? Or would formatting it screw with the partition setup on the drive? Reason being, this drive does have a retail copy (OEM Recovery partition) of windows 8 on it, with the computer that I pulled the drive from still being in good working order, so if I ever wanted to I could essentially just pop the drive back in and make use of that.
To be completely honest, I wouldn't be too bothered about losing the partition. It would be nice to be able to keep it intact, but, if formatting the drive normally is safe for the drive with the partition on there (but the partition gets erased) then I would just do that, it isn't a huge deal. So, are there any extra hoops I have to jump through in order to get this into working order because of the partition? Or can I simply go into the drives directory and just delete all the crap on it that way and get it up and running like that?
Disk Management will not let you "do that" per se.
Reference/resource link (good overview of it all):
https://www.partitionwizard.com/partitionmagic/delete-recovery-partition.html
And from within this forum an older link:
http://www.tomshardware.com/forum/282263-32-format-hard-disk-recovery-partition
If you are able and willing to say goodbye to Windows 8, keep things simple and re-use the old hard drive with as clean of a start as you can.
Otherwise, just leave the OEM recovery partition intact and hopefully it will work as intended sometime later if Windows 8 needs to be reincarnated. Just be sure to create the necessary recovery media to do so.
Then only the current C: partition will need to be reformatted. You could...
You can do it safely. The important point to recognize is that Formatting and Partitioning are two different tasks. Recent versions of Windows make it easy to do these on a new empty drive by combining them into one Wizard, but the separate steps are still maintained. Only the automated process is made easier.
In earlier versions of Windows, on a new empty disk you FIRST had to Create a Partition. That reserved a chunk of space to be used as a drive. You have the option of using all of the HDD's space in this one Partition, or of making it smaller than that. The Creation of the first MBR Partition also creates the disk's Partition Table in a particular fixed location on the surface, which contains the details of all its Partitions and which is limited to no more that 4 Partitions because that's all the space allowed in the MBR Partition Table structure. Once that has been done, you can Create more Partitions (up to 4 total) from the remaining Unallocated Space. Doing that in each case simply enters the appropriate data into that Partition Table. Now any system accessing the HDD can read the Partition Table (it's at a known "standard" location) and find out exactly where each Partition is and use them.
AFTER one or more Partitions are created, each must separately be Formatted. Formatting writes the necessary files to that ONE Partition to create the File System on it. A Format operation is carried out on only ONE partition at a time, and does NOT affect any other Partition. Only after BOTH operations have been completed can your OS access a Partition and use it for data.
So in your case, OP, you most certainly CAN do a Format only on one Partition without affecting any other. Just be VERY careful that you do that on the Partition you want to wipe clean, and not on one you want to save. I would suggest you do a Full Format, which can take hours. This process will test every Sector in that Partition and write useless zeroes to them. In the process, if it finds any that are not working properly, it will make them as Bad Sectors in Windows' files on that "drive" and prevent Windows from ever trying to use them. (A "drive", by the way, is one Partition that Windows gives a letter name to and treats as one storage unit called a "drive". To Windows, the term "drive" does not necessarily mean an entire HDD unit's space.)
Then only the current C: partition will need to be reformatted. You could assign that partition a new drive letter on your own or just let Windows assign a letter for you.
Best to read up on the formatting/reformatting process beforehand. Especially if there are other partitions on the disk.
