Wall seems like an ordinary structure but to be honest, it is an incredible structure that lets you create a lot of different structures. To create all structures with wall, take a look at the instructions below:
Basic Wall:
This is the simplest form of the wall. You can create it by just selecting the wall and placing it. It provides cover from enemy fire.
Window:
This one is also very easy to create. All you need to do is to deselect the middle section of the wall to create a window in it. You can do this by clicking on the middle section. It will let you see enemies on the other side.
Side Windows:
Another very easy to create structure. What you need to do is to click on the sections that are at the right and left of the middle section to make them disappear.
Door:
Creating a door is also an easy thing to do. You can create a door by clicking on the middle section and the section beneath it to deselect them both.
Window Door:
You can create a window and a door through a wall. To do this, you need to deselect the section to the right side of the middle section and the section beneath it. This will create door, and to create the window, you need to click on the section to the left of the middle section.
Half wall Door:
To create a half wall, deselect all the top sections and then to create a door with it, deselect the sections on the right side.
Arch:
To create an arch, all you need to do is to deselect the middle section and the whole line beneath the middle line.
Half Arch:
Creating a half arch is not difficult. You need to keep the left side line of sections and the above line of sections selected and deselect the remaining 4 sections to create a half arch.
Triangle:
You need to deselect the upper two sections of the right line and the section above the middle section. This will create a triangle.
Half Wall:
Pretty easy to create the half wall. All you need to do is to deselect the line of upper sections and this will create a half wall.
Low Wall:
In order to create a low wall, you will need to only keep the line of lower sections selected and deselect all the remaining ones.
Partial Low Wall:
To create the partial low wall, you will need to deselect all the sections besides the lower section of middle line and the lower section of the right line.
Partial Half Wall:
To create the partial half wall, you will need to deselect all sections besides the middle and lower sections of the right line.
Column:
It is very easy to create a column. You just need to leave the whole right line selected and deselect all other sections.
These are all of the possible structures that you can edit out of a wall. Make sure to read the instructions carefully to create them correctly.
Basic Wall:
Window:
Side Windows:
Door:
Window Door:
Half wall Door:
Arch:
Half Arch:
Triangle:
Half Wall:
Low Wall:
Partial Low Wall:
Partial Half Wall:
Column:
