G Guest Guest Oct 17, 2011 #1 hello i have a foxconn p4m9007ms 8rs2h mother board and i would like to know and in which order the pin settings go please any help would be greatfull thanks
O o1die Illustrious May 16, 2001 14,175 0 42,960 Oct 17, 2011 #2 Here is the manual http://www.foxconnsupport.com/download.aspx?models=en-us0000243&category=C000000001&series=en-us0000002&keywords=&sort=Motherboard off foxconn's webpage. You should find all the pin positions. If you have never used the board before, I suggest you test it first before mounting it in a case, on a non conductive surface.
