Hey
My rig: Msi Gtx 1080 8gb, I5 6600k, 16gb hyper x fury 2600, Mobo: MSI B250M PRO-VD
My problem is that In a lot of games I have a good fps around 100 but on every preset usually on ultra the games look bad It doesn't look like a gtx1080 quallity.
In Rdr2 on ultra, high, medium, presets I have the same fps around 35-45. Its not that bad but Im not satisfied, around 40 fps its "okay" .
Is there something Im missing or is it just the game, its a kinda fresh release. The main problem of my post is the shuttering in Red Dead 2, Im monitoring my components with Riva tuner, Usually my gpu is on 85% as options says the game use less than 50% vram during the game.
My cpu is on: 50%
8600mb Memory use
Gpu cpu etc temperature are all fine nothing serious, sometimes the gpu goes up to 74celsius and thats it.
At nvidia options I changed the power options from quallity to performance, it gaved only 5fps.
I start the game, I walk around for 1 minute and the screen stucks, after 4 seconds its coming back and everything is smooth, It happens like every 3rd minute.
This rig is kinda new I got these components and made a rig for gaming,
Is there something Im missing, usually I install the opsystem, and uptade my drivers especially the gpu driver. Should I update my bios or cpu.
Im pretty sure that my monitor is not the best maybe it can cause the bad graphics.
I also calibrated the memory frequency to the best actually auto setting is proper too.
If there's anything you can help with, any tips or solutions, pls tell me.
Cheers
My cpu is on: 50%
8600mb Memory use
Cheers
