FPS dropping months after building
Bavvh
38
Hey folks.
I built this system a few months ago, and the last couple of days I've noticed my FPS has dropped quite a bit. WoW went from 75-80 FPS down to 60-70. It's a small drop, but it's making me mad that I can't figure out what did it. The only thing that's changed is adding a second monitor. Could that cause that big of a drop? It's the same brand as my other one. The primary is hooked up to DVI and the secondary is on the HDMI.
System specs below. None of the drivers are out of date according to SlimDrivers. The GPU temp sits at 60-65c with one game running and a couple of browser tabs open. I'm still fairly new to hardware issues, so any help would be lovely.
SiSoftware Sandra
Computer
Model : GigaByte H87-D3H
Serial Number : To be fille***********
Chassis : GigaByte Desktop
Mainboard : GigaByte H87-D3H-CF
BIOS : AMI (OEM) F5 08/03/2013
Intel vPro : 9.00.03.1347
Total Memory : 7.88GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz (4C 3.79GHz, 3.8GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC LGA1150
Chipset
Memory Controller : Gigabyte Core (Haswell) DRAM Controller 100MHz, 2x 4GB DIMM DDR3 1.33GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : Corsair CMZ8GX3M2A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-33-10-5)
Video System
Monitor/Panel : ViewSonic VX2370 SERIES (1920x1080, 23.0")
Video Adapter : AMD Radeon HD 7900 Series (28CU 1792SP SM5.0 1GHz/850MHz 17% OC, 3GB DDR5 5GHz 384-bit, PCIe 3.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon HD 7900 Series (1792SP 28C 1GHz/850MHz 17% OC, 3GB DDR5 5GHz 384-bit)
Compute Shader Processor : AMD Radeon HD 7900 Series (1792SP 28C 1GHz/850MHz 17% OC, 3GB DDR5 5GHz 384-bit)
Compute Shader Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.2GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics)
Storage Devices
Samsung SSD 840 PRO Series (128GB, SATA600, SSD) : 119GB (C:)
WDC WD10EZEX-60ZF5A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (F:)
WDC WD3200AAKS-00B3A0 (320.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (G:)
ATAPI iHAS124 W (SATA150, DVD+-RW, CD-RW) : N/A (D:)
DTSOFT BDROM () : N/A (E:)
Logical Storage Devices
System Reserved : 350MB (NTFS)
BACKUPS (G:) : 298GB (FAT32) @ WDC WD3200AAKS-00B3A0 (320.1GB, USB2/SATA300, 3.5", 7200rpm, 16MB Cache)
Hard Disk (C:) : 119GB (NTFS) @ Samsung SSD 840 PRO Series (128GB, SATA600, SSD)
DATA (F:) : 932GB (NTFS) @ 2x WDC WD10EZEX-60ZF5A0 (1TB, RAID/SATA600, 3.5", 7200rpm)
Optical Drive (D:) : N/A @ ATAPI iHAS124 W (SATA150, DVD+-RW, CD-RW)
Optical Drive (E:) : N/A @ DTSOFT BDROM ()
Peripherals
LPC Hub Controller 1 : Gigabyte Lynx Point LPC Controller
LPC Legacy Controller 1 : ITE IT8728F
Audio Device : Intel Core (Haswell) HD Audio Controller
Audio Codec : Intel 2807
Audio Device : Gigabyte Lynx Point HD Audio Controller
Serial Port(s) : 2
Disk Controller : Gigabyte Lynx Point 6-Port SATA AHCI Controller
USB Controller 1 : Gigabyte Lynx Point USB xHCI Host Controller
USB Controller 2 : Gigabyte Lynx Point USB Enhanced Host Controller #2
USB Controller 3 : Gigabyte Lynx Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : HP LaserJet 400 M401 PCL 6 (600x600, Colour)
Printer : Microsoft XPS Document Writer v4 (600x600, Colour)
Printer : Foxit Reader PDF Printer Driver (600x600, Colour)
Fax : Microsoft Shared Fax Driver (200x200)
Peripherals
Media Player : WD 3200AAK External (298GB)
Media Player : Apple iPhone (14.77GB)
Network Services
Network Adapter : Intel(R) Ethernet Connection I217-V (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 8.1 Professional 6.03.9600
Platform Compliance : x64
fixer762
322
Yeah I think the second monitor is it. Try it with a single monitor and a dual monitor with WoW and some other games that you play. That way you have more data to see what is going on with your frames per second.
Nice build.
Bavvh
38
I did unhook the secondary monitor, but it didn't seem to do much. FPS went up a hair, but nothing to write home about. I'll try opening up the case and giving it a thorough clean tomorrow.
And thanks for the compliments. The lovely Tom's community helped me with the part selection :) It runs anything I throw at it so far.
Chickenator
228
Hi, yes, the performance is reduced by adding another monitor because it will need to produce frames for that screen too. (more frames to that monitor = reduced fps in main monitor).
Have you turned your PC in power saving mode by any means? That will significantly reduce performance. If not, make sure you have it set for "high performance" in the control panel. Control panel > System and maintenance > Power alternatives (or something similar) then turn it to High performance, or max performance, whatever is written.
Bavvh
38
Everything is at high performance. Windows 8 has this awesome bug where it doesn't want to wake up if the HD goes to sleep, so everything is set to never turn off. I'm thinking I might have a little dust. I opened the case today to take a look, and it's a bit dusty in there. Hopefully cleaning it out will do it. I did get 5ish more frames with the other monitor turned off tho.
Chickenator
228
How long has it been since it last was turned off? Might as well be the source of the problem.
Is there a solution to this bug? Have you searched for it? Could you reinstall windows?
