can someone tell me why im getting fram drops in fortnite from like 120fps down to below 40fps and it tends to jump about, its so frustrating
what are your system specs in full, specifically how much ram and also what res are you playing on?
At 1080p a lot of games use close to and upward of 8gbs system ram. With only 8gbs, i'd say you are pretty stretched, specially with any chrome tabs open. 16gb is really the sweetspot for gaming now. Once your ram fills up, it starts to use the swap/page file, instead of system ram. This is much slower and can cause FPS drops and stuttering.
Monitor your cpu frequency and see if it drops when the fps drop.
Thanks alot for the advice mate. so do you think adding more ram will help it run more stable?
It potentially will. But also your GPU has 2gb Vram. Again, a lot of games use 2-3gbs of vram at 1080p. Your system is at it's max. Adding ram may help, but will only negate the real issue for a short time.
MSI Afterburner.what is the best way do that? is there a programme that will alow me to do so in game with an overlay i can keep my eye on while playing ?
Yes i understand that. i am in the middle of building a whole new PC anyway i just want a small cheap fix (if possible) for now while i build my new PC
MSI Afterburner.
It will also allow you to view many other things like temps, frequencies and usages(cpu, ram, gpu, etc).
I see. On that basis, the only option would be a ram update. (Cheapest option). There is a problem with that too though. You would need to find the exact same model ram as you have, to have a chance they will work together. Buying differrent ram DIMMS with different timings and speed and voltage and mixing them with what you have can be problematic. Sometimes they don't work together.
My advice is to stick with the pain for a while till you get the new PC built. Don't put any more money into your current system even for a quick fix.
I'd use afterburner to monitor memory usage(along with the others temps and frequencies) to make sure that's the issue before spending any money.I'm sure i can find 16gb second hand for now
I don't. But I did post some instructions above.Do you know of a video link showing me how to set up afterburner to do so ? that would be a massive help
