Okay, so 6 years for a CX is about as good as you can get. It has a 5 yr warranty. Whilst not the worst PSU, it's certainly not the best, and if the power delivery is not stable as it should be, it could very well be the cause. PSU's degrade over time.XMP Profile 2 (3000mhz) Dual Channel 32GB 2x16GB I have tried multiple power plans to no avail I tried the bitsum power plan as well at one point and that also did not help and the PSU is 6 years old I found the email recipt and yes i have updated my bios
Build:
Sorry! I accidentally pressed enter instead of shift enter and it posted this I was still writing it out I posted another one with all the other details if you wouldn't mind looking at itHey there,
We need slightly more info!Please provide your system details, along with monitor type/res and PSU.
XMP Profile 2 (3000mhz) Dual Channel 32GB 2x16GB I have tried multiple power plans to no avail I tried the bitsum power plan as well at one point and that also did not help and the PSU is 6 years old I found the email recipt and yes i have updated my biosHey again,
Can you let us know what ram you have and in what configuration?
So, when you reset the OC's did you restore defaults in the bios? Or did you change back settings? If not try default, see if that helps.
Have you tried different power plans? High or Ultimate? This might also have an effect.
How old exactly is the PSU? You have a power hungry system at OC the 1080ti can suck up to 300+w , and although the PSU has enough watts, it's not exactly an OC type of PSU given it's medium level components. It might be it's not providing the correct power delivery for the GPU and is causing glitches.
Is your bios up to date?
Is there any way to test and see if my psu is the problem without buying another or is the only way to test it trial and errorOkay, so 6 years for a CX is about as good as you can get. It has a 5 yr warranty. Whilst not the worst PSU, it's certainly not the best, and if the power delivery is not stable as it should be, it could very well be the cause. PSU's degrade over time.
Given all you've tried I'd consider swapping it out. If you want to be sure before purchasing a new one, you could bring to local repair store, get them to swap out and test for maybe £$€20 or so. Then you can decide if you need a new one (which I would suggest doing anyway).
There are some very decent Gold rated units now for reasonable prices (still not for nothing thoug, maybe 70-90 or so).
Would you recommend upgrading from 750 to a higher wattage, gold rated PSU or would it be better if i were to get the same one againOkay, so 6 years for a CX is about as good as you can get. It has a 5 yr warranty. Whilst not the worst PSU, it's certainly not the best, and if the power delivery is not stable as it should be, it could very well be the cause. PSU's degrade over time.
