Question FPS drops on Ryzen 5 3400G, low MHz ?
Sm0
Commendable
Oct 28, 2021
6
Hello, I need some help. When I get a random fps drop, my CPU MHz+W decreases for about 5 seconds (examples at the bottom), I don't think the temperature is a problem since I have a max of 60/70 degrees playing. I wanted to know the solution and the cause of the problem.
Thanks.
My specs:
GIGABYTE B450M DS3H V2 AM4
AMD RYZEN 5 3400G
32GB DDR4 3000MHz CL16 Crucial Ballistix Black (4 sticks of 8GB)
HDD WD 2TB BLUE 256MB SATA 6.0GB/s
HDD WD1600AABS 160GB SATA 3.0GB/s
PSU Redragon 600W 80+ Bronze GC-PS002
Case Kolink Inspire X1
Cooler CPU ID-Cooling SE-902-SD
One 120mm fan in the back of my case
IGpu: Radeon Vega 11
Display LG Flatron W2252S 1680x1050 60hz
Software:
Windows 10 Home 64 Bits 21H1 19043.1320
AMD Adrenalin 21.10.3
Bios version: F61c, date 5/10/2021
No dedicated GPU (planning to buy an RTX 2080 or 3060ti)
No SSD (planning to buy an NVMe M.2)
Display (planning to buy one since I have some screen tearing on games and youtube videos)
Fans (planning to buy 4) [2 at the top and 2 at the front: something like this https://ibb.co/1TpK6Dx]
I have:
Never overclocked/undervolted my CPU/igpu
XMP activated in bios (for ram)
VT Virtualization activated (for bluestacks)
fTPM activated (for windows 11 test requirements)
Fan speed at maximum 1800 RPM in the back of my case
210GB left on my 2TB disk and I don't use my 160GB old HDD yet
Currently, I don't have an antivirus (I used avast before), now I use windows defender
Things I already tried:
Low and high details/textures/shadows on games
Sync on and sync off
Limited fps and unlimited
Fullscreen, windowed, and borderless.
Defrag my disk
Windows performance animations option to low
Disabling startup apps
Cleaning %temp% and temp folders
Uninstalling programs I don't use
Disabling GameDVR_Enabled and AllowGameDVR on the registry editor
Power plan to High Performance
Disabling Xbox game bar and Game mode
Reinstalling games
Malwarebytes, adwcleaner, super antispyware, virustotal
Enabling all CPU cores
and some more that I don't remember right now...
Temperatures (Celcius):
Example in Payday 2
Normal: https://ibb.co/LtMCQsc
Low fps: https://ibb.co/jLt9xXL
This is a video (not mine) example of what happens to me:
View: https://www.youtube.com/watch?v=dRt3mJiETh4
If I forgot to put more information, let me know and I will edit it or I will replying you
