Question Front panel connectors not working
xWiiperz
6
The front panel connector doesnt seem to work i checked if the case button cables are working using a multimeter and they do then i checked the motherboard manual to find the power button pins and then connected everything together but it doesnt start up i then tested to use the screwdriver trick but nothing happens, is there a way to check if the 2 pins on the motherboard are working using the multimeter or anyway to find the problem?
Update: I was able to figure out how to check if the power pins where working but looking how much volt was going through them and it was 3.35v but that means that the front panel pins are not the problem that the pc doesnt boot up, so theres then another problem. Heres some info i bought a new motherboard, cpu and ram and for some reason doesnt work together this is not my first building a pc but never had this problem before
Latest posts
