Fully control my CPU fan?
NOOKSAROUGE
13
With SpeedFan, when my CPU fan is on 100%, it is at 3184RPM - 3309RPM.
However, when my CPU is hot and under full load, it reaches nearly 5000RPM.
Is there a way to control it so that I can fully control the speed?
Well, I want to increase my fan speed, not decrease.
That'll cool it down.
akxpckwb: There are no settings whatsoever about fan speed in my BIOS. I checked all of the categories more than 5 times.
i agree zendesk could work
By the way, I know someone with exactly the same components as me (Phenom II X6 1055T, same motherboard, etc) and he can put his fan speed up to nearly 7000RPM.
If you need to run a fan at such high RPMs to keep core temperatures within a range you feel comfortable with, you might want to seriously consider upgrading your HSF. Most fans don't last very long at extreme RPMs and that thing must be ridiculously loud too.
Bump.
My fans are now fast. I don't know what I did, but I think I changed the minimum speed to 100% then restarted.
Now, they are almost always from 4000 - 6000 RPM.
If your CPU fan is running at 4000+RPM and your core temperature is still hitting 80C, you probably need a better heatsink-fan or at least double-check that it is still operating and mounted correctly.
My PC has a Hyper 212+ HSF and my CPU is only hitting 55C with the fan at 700RPM and 30C room temperature, only 1/10th the fan speed you are seeking.
