FX-8350 running at 1.92v!
jonnyapps
111
Just checked in CPU-Z and my new 8350 is running at 1.92 volts which is surely far higher than it should be? I haven't changed anything in the bios.
Any advice?
are you sure? it probably is false reading. what vcore is shown in bios? whats the temperature?
btw, 1.92 would not burn your house. i was running 1.8v at 5+ghz on fx-4100, but it was 99c idle
Reset the bios and it's back down with a min of 0.840 and a max of 1.404.
Bit confused about the bios - the motherboard is new. Out of the box I had the EZmode and Advanced mode but then I flashed to the latest version and now can't access EZmode - even when I click the option.
Do I have a bad flash or something?
