Question G Skill Trident Z Neo DDR4-3600MHz CL16-16-16-36 1.35V only works as standard 2133MHz
May 26, 2020
6
So.. i decided to upgrade my PC a tad..
Aorus Master Z490 (BIOS F3 and F5.. no difference)
I7 - 10700K
G Skill Trident Z Neo DDR4-3600MHz CL16-16-16-36 1.35V 2x16Gb.
PSU: Cougar GX Gold 1050
So.. the RAMM definitely doesn t work as specced. It doesn t even work at 3400. I got it to work at 3200 with 1.35 but the timings are automatically set to 22. If i try to manually set the timings (tried 14 14 ... 34) it works but when i check it with CPU ID it shows a Frequency of 2800 with said timings. IF i go into the BIOS again is still shows 3200.
Be that as it may... i did pay a rather hefty Premium for the 3600 (as opposed to let s say 3200 it s a 150E difference) and seeing as the other components are also supposed to be premium i don t see a reason why it doesn t work. Any ideas ? Before you ask. With XMP enabled and set at the advertised 3600 it doesn t boot.
The Gigabyte Bios is rather complicated. Maybe i should ve listened to the reviews and gotten a MSI or ASUS instead.. -.-
This sounds like possible Bios quirks with a new board.
Is that memory on the QVL list for that motherboard?
I just checked the QVL is this the kit?
3600G.SKILL 8GB1Rx8 F4-3600C16D-16GVKSS16-16-16-36 1.35v
or
3600G.SKILL16GB2Rx8F4-3600C16Q-64GTZRDS16-16-16-36 1.35v
I just picked up these same Ram sticks and i am having the same issue. When i tried setting the target speed in the Bios to 3600 the PC quick rebooted 5 times and then rejected the settings. Not sure how to fix it.
Ryzen 7 2700x
Asus Crosshair vii Hero mobo
GSkill Trident Z Neo 4x8gig (36 total gig)
ASUS ROG Strix GeForce® GTX 1060 6gig OC
Corsair RMX 850 Gold
Solved: Ramm was in 1/3 slots instead of 2/4. As soon as i changed them in 2/4 it worked at 3.600 with the correct timings.
Hi, I am planning to buy the same model of RAM you have. Did you put them on 2/4 slots from the right or left? I have Aorus Z370 mobo, will it recognize another pair of sticks with the same model when I add them in the future?
Check out the Motherboard manual but the 1 slot is the one nearest to the CPU. Also.. there are dual channel and quad-channel Kits. If you buy a dual channel one, like me ( meaning.. 2 sticks) you sticks with it or.. you sell your kit and buy a new quad channel one (that comes with 4 memory sticks). Pretty sure you t be able to add another dual channel on the existing one and run both at the specced speeds.
Ryzen 7 2700x
You should start your own post. With the processor you have it's rated for 3000 memory so 3600 might not ever get stable then your running 4 sticks on top of that.
Thanks!
