GA-8S648FX-L Microphone input
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hello,
The microphone input to my motherboard
is putting out a +2.5 volts on the tip
as related to the common and I was just
curious if this is normal for the microphone input
to be putting out this voltage ?
Regards;
gmv
I think I should add to this the following.
Stereo patch cord attached to Microphone input
RealTek AC97 Onboard sound adapter
Using a stereo plug
_
< > <--- +2.5V
| |<---- several milli volts
_| |_<--- common
Surely one of you out there has taken
a DVM to measure the voltages on
your patch cords ???
What measurements are you getting ?
Are these readings normal or is something wrong here ?
"gmv" <noemail@please.123> wrote in message news:rlHYc.3947$_g7.757@attbi_s52...
> Hello,
> Regards;
> gmv
Well on my board there is +5V on the tip and +1.25V on the ring, I've never
put a mic on this input. If your mic works I wouldn't worry too much about
it. It may be a bias voltage for cheap capacitor mics.
Adrian
news:qkQZc.91762$9d6.72754@attbi_s54...
> Using a stereo plug
> _
> < > <--- +2.5V
> _| |_<--- common
>> Hello,
>> Regards;
>> gmv
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.751 / Virus Database: 502 - Release Date: 02/09/2004
