Just built a new rig around the Gigabyte GA-P35C-DS3R mobo and boot freezes in the PCI Devices listing on the ACPI Controller entry, as shown from my picture here:
http://www.dataper.demon.co.uk/misc/helpme.jpg
I've cleared the cmos ram but there is no change. Repeatedly loaded optimised/fail-safe defaults and no joy. I've also deactivated other items on IRQ9 but it makes no difference - ACPI Controller can be the only item on that IRQ and it still stops booting at the same point.
Curiously after I had first switched it on I was able to boot into an Ultimate Boot CD, and I am not aware of doing anything significant since which would cause the problem.
Is anyone else having a similar problem, or better still, can anyone suggest a solution?
Or do you think the mobo has just failed?
Thanks!
Pete
Thanks!
Pete
