Hi guys I'm having a huge issue with video games crashing on my PC.
After a very short time of playing a game, the screen will freeze, the monitor will shut off leaving only a "No HDMI input" message on the screen. After a few seconds the image will return to normal, but the game is not responding and I have to shut it off via ctrl-alt-del and then task manager.
This only happens to very graphically intensive games such as Dark Souls 3 and Doom 4, older games such as half-life 2 and star wars battlefront 2 run perfectly fine. Many of the games that are crashing I could play perfectly fine previously.
I had a similar problem a few months ago when intensive games began crashing, I solved it when I found that my GPU's fans were locked at 35% speed for some reason and the card was overheating, no such luck now as my cards fans seem to be running normally. I have no idea what the problem is.
The only thing that I have changed about my PC is that I got a new 1080p monitor, I used my old monitor in tandem withy the new one as a dual display. I changed back to my old one on it's own to see if the problem was the monitor and the crashing still happens, I don't know how long this has been an issue as I hadn't played any modern games for a few months previous to the new monitor either. So I don't believe that to be the source of the issue. It's difficult to place exactly when this problem may have occurred as I'm only noticing it now, but I could have been going on for months for all I know.
I've cleaned and dusted the entirety of my pc's components and that hasn't resolved the issue.
I have updated all my driver and my BIOS, and that hasn't fixed the problem.
Here's my specs: (Aside from the new monitor, these have been my specs for the last 2-3 years and ran my games fine up until now.)
Monitor: BenQ GL2750H (Connected with HDMI.)
GPU: AMD Radeon HD 7870 Twin Frozr 2gb Edition.
CPU: AMD Phenom II x4 965 Black Edition.
PSU: Corsair 750 Watts.
RAM: 8GB
Thanks for any future help,
RAM: 8GB
