Hello everyone, I've recently installed a new copy of windows 7 and bought a Gigabyte 7770OC, but the card just doesn't act right for most games, I started out with Arkham City and it seemed to struggle to run so I switched to DX9 and things got a lot better (not perfect though.) Now I'm Witcher 2 and the GPU seems to run all settings of the game at 60+ framerates, then after a few mins of playing it drops to 15-30FPS, it doesn't matter if I switch to low or ulta settings, my framerate doesn't significantly change. I ran GPU-Z in the background and the game isn't even using 50% of the GPU's load and the temps are barely reaching over 55C. Now I thought my CPU (Q6600 quad core @2.4GHz) might be bottlenecking it so I tried the last game I have which was Prince of Persia, which runs on almost all GPUs out there, I started out with also 60-80 FPS then after a few mins of roaming it dropped to 30-40. It seems like the card is throttling every game I have, I barely reach temps of over 55C and my GPU load spikes up and down like a heartbeat monitor but barely goes over 60%. Is there something wrong with my settings? My GPU drivers are up to date.
A test through Furmark uses 99% of my GPU and takes the card's temperature to over 70C
Here's my specs:
4GB RAM
Gigabyte 7770-OC
Q6600 Quad Core @2.4 GHz (Stock clock)
Windows 7 32 bit
Thanks for the help in advance!
Here's my specs:
4GB RAM
Gigabyte 7770-OC
Windows 7 32 bit
