Hi, I'm planning to upgrade my pc in next 2 weeks, my budget is £600, can you have a look at what I have came up with ?
Kingston HyperX Fury Black 16GB (2x8GB) DDR3 PC3-14900C10 1866Mhz (£90- used)
GeForce GTX 1060 Jetstream RGB 6144MB GDDR5 PCI-Express Graphics Card (£260)
ASUS H81M-Plus Intel Socket 1150 Motherboard (£50)
Intel Core i5-4690K 4690K 4GHz Unlocked PC CPU 4690 K LGA1150 (£150-used- 2 years warranty)
ATX 500B power supply (already have)
Toshiba DT01ACA100 1TB (already have)
My questions are:
What kind of cpu cooler should I buy ?
Does the current power supply is enough ?
And.. does all of those parts are gonna be compatible and work well ?
Thanks
My questions are:
Thanks
