From the image posted previously, you can see artifacts (small squares) all over the screen if you look very closely. They were also moving southeast down the screen. Weapons on the floor were also bright (bloom) white :/
Update: I updated my BIOS to the latest version, and noticed that i had forgotten to uninstall nTune along with my drivers before installing the 280 >_< im wondering if ntune had been messing with the system.
I test played several games other than crysis, but the problems happened a lot more frequently with crysis. I'm back to driver 177.41, and so far (since uninstalling ntune and reinstalling drivers), the only problem ive had is that call of duty 4 bluescreened very early on. The eror message disappeared mmediately as the system rebooted, but there may be a log of it somewhere. I then reloaded and played the game for a good 2 hours, and the problem did not repeat itself.
I noticed that the voltage on 'VCore' was jumping past its threshold slightly, with the desired value being 1.19, and it jumping to 1.31 (monitored by Pcprobe, an Asus program for my motherboard). I was also running Speedfan at the time of the bluescreen, and i did not run it while playing CoD 4 afterwards... it may have been the cause of the crash. Other than that, 3 hours of gaming in crysis, call of duty, world of warcraft didnt recreate any glitching.
I'll update again after a longer session of gaming tomorrow, and ill post soe 3dmark vantage stats. Thanks again for all of your help.
