S sgtnebula14 Apr 10, 2018 5 0 10 Apr 10, 2018 #1 Is there any adapters or something of the sort that i can buy that would make my power supply compatible with this graphics card? Please help!
Solution okcnaline Apr 10, 2018 Spend some money now so you save a lot more in the future. Yes. Get a new PSU.
okcnaline Splendid Nov 17, 2013 8,083 5 26,965 Apr 10, 2018 #2 How about replace your PSU if you need to run molex to your GPU. Upvote 0 Downvote
S sgtnebula14 Apr 10, 2018 5 0 10 Apr 10, 2018 #3 i was wondering if i could save the money and see if there was another option but if there isn't one id have to buy a new psu? Upvote 0 Downvote
okcnaline Splendid Nov 17, 2013 8,083 5 26,965 Apr 10, 2018 Solution #4 Spend some money now so you save a lot more in the future. Yes. Get a new PSU. Upvote 0 Downvote Solution
S sgtnebula14 Apr 10, 2018 5 0 10 Apr 10, 2018 #5 okcnaline : How about replace your PSU if you need to run molex to your GPU. If i was to purchase a new psu could you recommend one i should buy? Id really appreciate it Upvote 0 Downvote
okcnaline Splendid Nov 17, 2013 8,083 5 26,965 Apr 10, 2018 #6 In general, the G3 550W or Focus 550W. What CPU and is it overclocked? Upvote 0 Downvote
S sgtnebula14 Apr 10, 2018 5 0 10 Apr 10, 2018 #7 The cpu is a i5 7500 Kaby Lake 7th Gen. Not overclocked. Upvote 0 Downvote
S sgtnebula14 Apr 10, 2018 5 0 10 Apr 10, 2018 #9 okcnaline : Budget? psu budget is £50 with a little wiggle room of course Upvote 0 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,511 1,627 159,590 Apr 10, 2018 #10 https://uk.pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na Upvote 0 Downvote
