[SOLVED] Gemini/twin/dual system case
LORYT699
Commendable
Apr 6, 2022
190
6
1,595
Hi,
As title I m searching some case for a dual atx system.
I'd like to know every dual system case for choose the one better for me.
Also I'd like if you can tell me how exactly it work, is just like 2 case paired or there are some features that I shuld look befor buy(example 1 psu for both system, or things like that)?
Thanks for the help
it sounds like you need to do some research as I don't know if there is a list of every choice
Here are 10 - https://www.setupgamers.com/dual-system-pc-case/
find names, go to website of case and/or watch Youtube videos about them.
Or just find some names, I saw Gemini mentioned on one of the links.
thanks, afeter read the article I think I will stay on my actual set up XD
