Hello, I just wanna know if there’s something I can do to make my temps cooler, I got this pc about 8 months ago and everything was fine, I’ve been playing games and didn’t have any issue until a few weeks now, recently I’ve been getting higher temps I used to idle at 35-40 now I idle at 45 and some times when I’m playing a game it gets to 70-80 and when I close everything to idle it stays at 60 c, there were times when it would get to 70c with nothing open, i change the power settings of the cpu, and it helped for some time, but now I can’t play heavy games because my cpu would get to 80 or more and still I get stuttering during games, I already tried cleaning the radiator which wasn’t that dusty, also reapplied thermal paste 3 times and still the same, I also tried to get a better case airflow, which I don’t think is a problem because it was fine 2months ago, my only idea is that the aio cooler is broken or maybe the pump is failing, my pc specs are:
Rtx 3080 ti
AMD Ryzen 9 3900x
Cougar Aqua 240mm AIO
EVGA 850W BQ Plus Bronze
Asrock B550 steel legend mother board
32 Gb ram DDR4 XPG Spectrix D50
1T SSD XPG SPECTRIX S20G
And I used the thermal grizzly kryonaut thermal paste.
All of those have around 8 months of use, and I have plenty of space on my sad
Also my room temp when I play games is usually 18-20c which shouldn’t be that hot, and when the cpu is under load to 100% it would get to 90c that’s why I keep it at 80% on the power options settings.
Rtx 3080 ti
AMD Ryzen 9 3900x
