Question Gigabit Issue ZyXEL VMG4381-B10A
tertmagert
29
Hello,
I currently upgraded with Fioptics gigabit internet by cinci bell. They have a 2-1 modem wifi router installed. ZyXEL VMG4381-B10A. Speedtest.net is only showing 170mbps down and 230mps up. My apartment has cat 5e cables running through the walls and then I have a cat 5e cable running from the wall connector to my PC. Mobo is GIgabyte Gaming 7 wifi. Can anyone offer some help as to why I wouldnt be getting more toward gigabit download speeds?
Thanks!
Start by bypassing the in-wall cabling and running a cable across the floor temporarily. But, since you are getting greater than 90Mbit, your PC has negotiated a 1GE link from the PC to the router. Your performance problems could be because of the Killer network hardware. Try the Intel ethernet port on the motherboard.
I googled the intel ethernet port but am not finding a good solution. I have the x470 version of gigabytes gaming 7 mobo. I only see one ethernet port on the back IO panel.
I should also note at my last place I had a 200mbps connection and received 230mbps wihtout fail.
I did bypass the wall connection and went straight to the modem and got the same results.
Sorry, I googled your description and got a different motherboard... Not the X470 version but an earlier Intel version.
