My pc details :
Mobo : Gigabyte EP45-UD3P
CPU : E7400 2.88 Ghz
RAM : 4GB
GPU : Ati 4850
Modem : D-Link DSL-2640T(wireless ADSL2+Router)
The motherboard have 2 port for LAN. After this build the both port LAN work
smoothly to connect to modem. Yesterday the first LAN port unable to use., but the
second LAN port can use. This happen when I switch on the pc and modem . Then I
switch off the modem accidentally. Then i switch on back, the first LAN did't
connect to modem and I have check the LED at first LAN port is not on. Then I change
to second LAN port, it work.
____________________________________________________________________________________________________
GhislainG
I dont know about DHCP and NICs teamed.
I'm using dynamic IP, not using static IP addresses
