Hello,
I have recently built my new PC and the first thing I noticed is the GPU fan noise (= Really loud, gets annoying to a point where I worry whether my GPU is defective or not).
Now, I tried the MSI Afterburner software to adjust my GPU fan speed to lower the fan sound (I hope I used the program correctly with 'start with windows' & 'start with minimized' and set my fan curve), however, It will not do any change to my GPU fan. The AB says that my fan speed % is at 40 % although I set it to 25 % (min), at just 40 % the fan sounds even louder than my Xbox360 fan which is really messed up. This PC is not only for gaming but for my daily uses for schools/etc. If I have to do homework/studying, this constant loud fan sound will just disturb me.
I am now wondering if this fan speed & sound that I am getting is the MAX speed the fan is set to originally? or is it possible that my GPU is defective?
FYI, my idle temperature is around 38-40 C and when I run diablo 3 or LoL, it goes up to around 50-60 C with constant fan speed/sound.
Please help me fix this!!
Thanks
Don't...
Bump posts
http://www.tomshardware.com/forum/283384-33-read-first
Thanks
Don't...
Bump posts
