Going Wireless on an Older Laptop
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have a Winbook laptop, Win XLi, Win 95, and Pentium II. Is it possible to
wireless with it by adding some external device through a USB port or otherwise?
Wayne T. Watson (Watson Adventures, Prop., Nevada City, CA)
(121.015 Deg. W, 39.262 Deg. N) GMT-8 hr std. time)
Obz Site: 39° 15' 7" N, 121° 2' 32" W, 2700 feet
"It is indeed a feeble light that reaches us from the starry
sky. But what would human thought have achieved if we could
not see the stars?" -- Jean Perrin
Web Page: <home.earthlink.net/~mtnviews>
> possible to wireless with it by adding some external device through a
Maybe - but not with any security on the wireless network.
It's doubtful the OS would support it or the drivers for the wireless device
for that old of an OS would either.
Shenan Stanley
MS-MVP
How To Ask Questions The Smart Way
http://www.catb.org/~esr/faqs/smart-questions.html
In news:F21Ve.1084$LS5.911@newsread3.news.pas.earthlink.net,
W. Watson <wolf_tracks@invalid.com> had this to say:
My reply is at the bottom of your sent message:
Here is ONE such example:
http://www.netgear.com/products/details/MA111.php
Searching might find you alternatives and better products. That's the first
one that came up in my search though.
Galen
"You know that a conjurer gets no credit when once he has explained his
trick; and if I show you too much of my method of working, you will
come to the conclusion that I am a very ordinary individual after all."
Sherlock Holmes
> to wireless with it by adding some external device through a USB port or
> otherwise?
Good luck!
System Requirements:
o Windows 98SE, Me, 2000 or XP
Errr ... the orig. poster is running Windows 95.
FWIW, I've never seen ANY wireless NICs or USB adapters that run on
Windows 95. And running one with Windows 98/ME is asking for a
maintenance nightmare. Been there, done that.
For me, in the long run it was cheaper (and a WHOLE LOT less work, IMO)
to buy an OEM Windows XP Pro CD and rebuild the system with that.
> IMO) to buy an OEM Windows XP Pro CD and rebuild the system with that.
I believe that only Win95 rev C is compatible with USB at all. Does your
laptop have USB plugs to begin with? You might try a card adapter. I ran
win95 on a 486 on a wired LAN so it is very likely that you will connect
fine.
In news:yk1Ve.29565$ih4.7121@fe02.lga,
Z <Z@no.spam> had this to say:
LOL Nice, wow... I suppose it was the whole "windowsxp.general" thing that
made me miss the 95... In fact I was wondering why anyone would be asking
that with all the various USB WiFi offerings.
Galen
Sherlock Holmes
> Good luck!
My machine does have actual USB ports, but I doubt they are USB 2.0.
Possibly tne CD Win XP Pro update might help. Although, I use XP Pro on my
desktop, I'd settle for just plain XP (home). Not sure what Win 95 it has. C ?
I may tempt it anyway. I was at Staples and they had Linksys wireless G
adapters for USB, 65Mb--$40 or $50.
>> Good luck!
> on my desktop, I'd settle for just plain XP (home). Not sure what Win
> 95 it has. C ?
> G adapters for USB, 65Mb--$40 or $50.
Do you have anything around that is USB and could see if it is seen in win
95 OS?
Jimmy wrote:
>>>Good luck!
>>95 it has. C ?
> 95 OS?
Yes, I guess you are hinting that I try it. Sounds like a good idea.
