[SOLVED] gpu fan stopping, starting, stopping, starting...etc... HELP
Jun 25, 2019
4
My new Zotac 1070ti's second fan (one furthest from connection to motherboard) ramps up to speed, stalls out, then spins back up. While the gpu didnt heat up too much under load it did rattle almost constantly due to the fan. Any solutions?
Figured it out! Turns out the fan was just wearing out in a weird way. After some tinkering and lubricating, all is fine. Although I may try and replace the fan soon.
