Last night I was playing NBA 2k21 and I got the following graphic glitches
When this happened, I was on a Google hangouts and my friends told me to mute because they could just hear a terrible static sound. I'm using the Elgato Wave:3 microphone which has an off button on it. I pressed and they told me that the static is still going on. I had to press the Hangouts mute button or pull out the cable of the microphone for it to stop.
I then tried my Hyper X cloud II's microphone, and the same thing happened with the static.
I've updated all drivers and windows and this is still going on. In addition, my Thunderbird is just flickering and flashing all the time.
GPU Temps seem fine
Whenever I try to open 2k21, same glitch happens and the game crashes. Is my GPU cooked and took the motherboard with it ??
Specs:
OS sitting on a 254GB Crucial SSD that has 90GB free space. Everything else is on a 1TB SSD Crucial MX500 CT1000MX500SSD1 that has 600GB free
Speccy link: http://speccy.piriform.com/results/v6sRe5ESDlvzbEKbePjm1K0
Windows: Windows 10 Home
Windows Version: 21H1
BIOS:
CROSSHAIR VI HERO BIOS 7901
One more thing I just came across:
When using the "Listen back" feature to listen to your own microphone via your headphones, the static / buzzing noise isn't there anymore. On the other hand, using it with Google hangouts, slack, discord etc. the buzzing is still there according to my friends.
And here's my HWMonitor voltage info if it helps
GPU Temps seem fine
Specs:
- PSU: Kolink Continuum 1050W 80 Plus Platinum Modular Power Supply - Bought in 2018 - Condition: Bought new back then.
- AMD Ryzen 5 3600 Processor
- Asus GeForce GTX 1060 Dual OC 6144MB GDDR5 PCI-Express Graphics Card
- Asus ROG Crosshair VI Hero AMD X370 (Socket AM4) DDR4 ATX Motherboard
- Corsair Vengeance RGB PRO 32GB (2x 16GB) 2666MHz DDR4 RGB RAM
BIOS:
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.4.0
Monitoring
Mainboard Model CROSSHAIR VI HERO (0x000004BB - 0x70D6D7F0)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8665
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8665
LPCIO Revision ID 0x6
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 86 65 06 40 27 D0 DB 81 04 D4 80 49 85 38 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Asus WMI
Voltage 0 1.35 Volts [0x149FB0] (CPU Core Voltage)
Voltage 1 0.96 Volts [0xEA2E0] (CPU SOC Voltage)
Voltage 2 1.13 Volts [0x114C20] (DRAM Voltage)
Voltage 3 0.98 Volts [0xEF808] (VDDP Voltage)
Voltage 4 1.74 Volts [0x1A9C80] (1.8V PLL Voltage)
Voltage 5 11.90 Volts [0xB59F50] (+12V Voltage)
Voltage 6 5.01 Volts [0x4C81F0] (+5V Voltage)
Voltage 7 3.29 Volts [0x323A98] (3VSB Voltage)
Voltage 8 3.05 Volts [0x2E91E0] (VBAT Voltage)
Voltage 9 3.29 Volts [0x323A98] (AVCC3 Voltage)
Voltage 10 1.05 Volts [0x100590] (SB 1.05V Voltage)
Current 0 26.00 Amps [0x1A] (CPU VRM Output Current)
Temperature 0 55 degC (131 degF) [0x37] (CPU Temperature)
Temperature 1 39 degC (102 degF) [0x27] (CPU Socket Temperature)
Temperature 2 34 degC (93 degF) [0x22] (Motherboard Temperature)
Temperature 3 58 degC (136 degF) [0x3A] (Chipset Temperature)
Temperature 4 43 degC (109 degF) [0x2B] (CPU VRM Temperature)
Fan 0 4141 RPM [0x102D] (CPU Fan)
Fan 1 1033 RPM [0x409] (Water Pump)
Fan 2 1525 RPM [0x5F5] (CPU OPT)
Hardware monitor DIMM
Temperature 0 42 degC (107 degF) [0xC29C] (core)
Temperature 0 42 degC (107 degF) [0xC2A1] (core)
Hardware monitor D3D
Hardware monitor NVIDIA NVAPI
Voltage 0 0.65 Volts [0x28A] (GPU)
Power 0 11.56 W (GPU)
Temperature 0 54 degC (129 degF) [0x36] (GPU)
Temperature 2 62 degC (143 degF) [0x3E] (Hot Spot)
Fan 0 0 RPM [0x0] (GPU #0)
Fan PWM 0 7 pc [0x7] (FANPWMIN0)
Clock Speed 0 683.00 MHz [0x2AB] (Graphics)
Clock Speed 1 810.00 MHz [0x32A] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
CPU Groups 1
CPU Group 0 12 CPUs, mask=0xFFF
Number of sockets 1
Number of threads 12
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- CCX 1
-- Core 3 (ID 4)
-- Thread 6 8
-- Thread 7 9
-- Core 4 (ID 5)
-- Thread 8 10
-- Thread 9 11
-- Core 5 (ID 6)
-- Thread 10 12
-- Thread 11 13
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 6 (max 6)
Number of threads 12 (max 12)
Manufacturer AuthenticAMD
Name AMD Ryzen 5 3600
Codename Matisse
Specification AMD Ryzen 5 3600 6-Core Processor
Package Socket AM4 (1331)
CPUID F.1.0
Extended CPUID 17.71
Core Stepping MTS-B0
Technology 7 nm
TDP Limit 65.0 Watts
Tjmax 95.0 �C
Core Speed 4199.0 MHz
Multiplier x Bus Speed 42.0 x 100.0 MHz
Base frequency (cores) 100.0 MHz
Base frequency (ext.) 100.0 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision 0x8701021
L1 Data cache 6 x 32 KB (8-way, 64-byte line)
L1 Instruction cache 6 x 32 KB (8-way, 64-byte line)
L2 cache 6 x 512 KB (8-way, 64-byte line)
L3 cache 2 x 16 MB (16-way, 64-byte line)
Max CPUID level 00000010h
Max CPUID ext. level 80000020h
FID/VID Control yes
# of P-States 3
P-State FID 0x890 - VID 0x48 (36.00x - 1.100 V)
P-State FID 0xA8C - VID 0x58 (28.00x - 1.000 V)
P-State FID 0xC84 - VID 0x68 (22.00x - 0.900 V)
PStateReg 0x80000000-0x49120890
PStateReg 0x80000000-0x47160A8C
PStateReg 0x80000000-0x459A0C84
PStateReg 0x00000000-0x00000000
Package Type 0x2
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Power Unit 0.0
SMU Version 46.62.00
TDP/TJMAX 0x41005F
TCTL Offset 0x0
Temperature 0 56 degC (131 degF) (Package (Node 0))
Voltage 0 1.43 Volts (CPU VDD)
Voltage 1 1.42 Volts (VID #0)
Voltage 2 1.42 Volts (VID #1)
Voltage 3 1.42 Volts (VID #2)
Voltage 4 1.42 Volts (VID #3)
Voltage 5 1.42 Volts (VID #4)
Voltage 6 1.42 Volts (VID #5)
Power 00 45.69 W (Package)
Power 01 3.41 W (Core #0)
Power 02 3.72 W (Core #1)
Power 03 4.20 W (Core #2)
Power 04 3.30 W (Core #3)
Power 05 8.03 W (Core #4)
Power 06 3.40 W (Core #5)
Power 07 26.03 W (Cores)
Clock Speed 0 4199.02 MHz (Core #0)
Clock Speed 1 4199.02 MHz (Core #1)
Clock Speed 2 4199.02 MHz (Core #2)
Clock Speed 3 4199.02 MHz (Core #3)
Clock Speed 4 4199.02 MHz (Core #4)
Clock Speed 5 4199.02 MHz (Core #5)
Core 0 max ratio (effective) 42.0
Core 1 max ratio (effective) 42.0
Core 2 max ratio (effective) 42.0
Core 3 max ratio (effective) 42.0
Core 4 max ratio (effective) 42.0
Core 5 max ratio (effective) 42.0
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 512 KB, 2 thread(s)
Cache descriptor Level 3, U, 16 MB, 6 thread(s)
CPUID
0x00000000 0x00000010 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00870F10 0x000C0800 0x7ED8320B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000011
0x00000006 0x00000004 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x219C91A9 0x00400004 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000207 0x00000340 0x00000380 0x00000000
0x0000000D 0x0000000F 0x00000340 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x0000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000F 0x00000000 0x000000FF 0x00000000 0x00000002
0x00000010 0x00000000 0x00000002 0x00000000 0x00000000
0x80000000 0x80000020 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00870F10 0x20000000 0x75C237FF 0x2FD3FBFF
0x80000002 0x20444D41 0x657A7952 0x2035206E 0x30303633
0x80000003 0x432D3620 0x2065726F 0x636F7250 0x6F737365
0x80000004 0x20202072 0x20202020 0x20202020 0x00202020
0x80000005 0xFF40FF40 0xFF40FF40 0x20080140 0x20080140
0x80000006 0x48006400 0x68006400 0x02006140 0x01009140
0x80000007 0x00000000 0x0000001B 0x00000000 0x00006799
0x80000008 0x00003030 0x010CB657 0x0000700B 0x00010000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00008000 0x00000000 0x0013BCFF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF040F040 0x00000000 0x00000000 0x00000000
0x8000001A 0x00000006 0x00000000 0x00000000 0x00000000
0x8000001B 0x000003FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000001D 0x00004121 0x01C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x01C0003F 0x0000003F 0x00000000
0x8000001D 0x00004143 0x01C0003F 0x000003FF 0x00000002
0x8000001D 0x00014163 0x03C0003F 0x00003FFF 0x00000001
0x8000001E 0x00000000 0x00000100 0x00000000 0x00000000
0x8000001F 0x0001000F 0x0000016F 0x000001FD 0x00000001
0x80000020 0x00000000 0x00000002 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000018
MSR 0xC0010058 0x00000000 0xF8000019
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000708A8
MSR 0xC0010064 0x80000000 0x49120890
MSR 0xC0010065 0x80000000 0x47160A8C
MSR 0xC0010066 0x80000000 0x459A0C84
MSR 0xC0010067 0x00000000 0x00000000
MSR 0xC0010068 0x00000000 0x00000000
MSR 0xC0010069 0x00000000 0x00000000
MSR 0xC001006A 0x00000000 0x00000000
MSR 0xC001006B 0x00000000 0x00000000
MSR 0xC0010299 0x00000000 0x000A1003
MSR 0xC001029B 0x00000000 0x4E7D27BB
MSR 0xC001029A 0x00000000 0x17E428AF
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x00870F10 0x010C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000001
0x8000001E 0x00000001 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0xC0010293 0x00000000 0x0006C8A8
MSR 0xC001029B 0x00000000 0x4E7EAC37
MSR 0xC001029A 0x00000000 0x17E451AE
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00870F10 0x020C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000002
0x8000001E 0x00000002 0x00000101 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x0008C8A8
MSR 0xC001029B 0x00000000 0x4E803277
MSR 0xC001029A 0x00000000 0x1BBE0348
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x00870F10 0x030C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000003
0x8000001E 0x00000003 0x00000101 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x4E81C876
MSR 0xC001029A 0x00000000 0x1BBE37AE
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x00870F10 0x040C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000004
0x8000001E 0x00000004 0x00000102 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x4E8343B0
MSR 0xC001029A 0x00000000 0x1980444D
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x00870F10 0x050C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000005
0x8000001E 0x00000005 0x00000102 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x4E84E9D7
MSR 0xC001029A 0x00000000 0x19807148
CPU Thread 6
APIC ID 8
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x00870F10 0x080C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000008
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000008
0x8000001E 0x00000008 0x00000104 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x4E869AC2
MSR 0xC001029A 0x00000000 0x1517F51A
CPU Thread 7
APIC ID 9
Topology Processor ID 0, Core ID 4, Thread ID 1
CPUID
0x00000001 0x00870F10 0x090C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000009
0x0000000B 0x00000007 0x0000000C 0x00000201 0x00000009
0x8000001E 0x00000009 0x00000104 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x4E884917
MSR 0xC001029A 0x00000000 0x151823D7
CPU Thread 8
APIC ID 10
Topology Processor ID 0, Core ID 5, Thread ID 0
CPUID
0x00000001 0x00870F10 0x0A0C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000A
0x0000000B 0x00000007 0x0000000C 0x00000201 0x0000000A
0x8000001E 0x0000000A 0x00000105 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000688A8
MSR 0xC001029B 0x00000000 0x4E89E623
MSR 0xC001029A 0x00000000 0x1F13CD6C
CPU Thread 9
APIC ID 11
Topology Processor ID 0, Core ID 5, Thread ID 1
CPUID
0x00000001 0x00870F10 0x0B0C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000B
0x0000000B 0x00000007 0x0000000C 0x00000201 0x0000000B
0x8000001E 0x0000000B 0x00000105 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x4E8B6EF5
MSR 0xC001029A 0x00000000 0x1F13FC21
CPU Thread 10
APIC ID 12
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x00870F10 0x0C0C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000C
0x0000000B 0x00000007 0x0000000C 0x00000201 0x0000000C
0x8000001E 0x0000000C 0x00000106 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000848A8
MSR 0xC001029B 0x00000000 0x4E8D1F91
MSR 0xC001029A 0x00000000 0x15EAE903
CPU Thread 11
APIC ID 13
Topology Processor ID 0, Core ID 6, Thread ID 1
CPUID
0x00000001 0x00870F10 0x0D0C0800 0x7ED8320B 0x178BFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x0000000D
0x0000000B 0x00000007 0x0000000C 0x00000201 0x0000000D
0x8000001E 0x0000000D 0x00000106 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x4E8EE488
MSR 0xC001029A 0x00000000 0x15EB1921
Storage
Drive 0
Name Crucial_CT275MX300SSD1
Revision M0CR031
Serial 1644148229B7
Capacity 256.2 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Controller Serial ATA Controller - AHCI at bus 1, device 0, function 1
Link Speed PCI-E 4x @ 8.0 GT/s
Volume c:\, 254.4 GBytes (31.9 percent available)
Drive 1
Name CT1000MX500SSD1
Revision M3CR032
Serial 2020E2A2A7A8
Capacity 931.5 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume d:\, 931.5 GBytes (63.2 percent available)
Drive 2
Name Samsung SSD 850 EVO 500GB
Revision EMT03B6Q
Serial S3R3NF0J963648P
Capacity 465.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume e:\, 465.8 GBytes (47.2 percent available)
Drive 3
Name SanDisk Ultra Fit
Capacity 28.6 GB
Type Removable
Bus Type USB (7)
Features
Volume f:\, 28.6 GBytes (99.3 percent available)
USB Devices
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x0145, product=0x0011
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x2008, product=0x0010
USB Device Elgato Wave:3, class=0x00, subclass=0x00, vendor=0x0FD9, product=0x0070
USB Device USB Mass Storage Device, class=0x00, subclass=0x00, vendor=0x0781, product=0x5583
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x03F0, product=0xEB2A
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x1B1C, product=0x1B5E
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x0951, product=0x16A4
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x045B, product=0x0209
USB Device USB Printing Support, class=0x07, subclass=0x01, vendor=0x0A5F, product=0x0027
USB Device Logitech USB Camera (HD Pro Webcam C920), class=0xEF, subclass=0x02, vendor=0x046D, product=0x082D
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x04F2, product=0x0603
USB Device Generic SuperSpeed USB Hub, class=0x09, subclass=0x00, vendor=0x045B, product=0x0210
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090306
Name NVIDIA GeForce GTX 1060 6GB
Board Manufacturer ASUSTeK Computer Inc.
Revision A1
Codename GP106
Core family 0x136 (GP106-A)
TDP 120.0 W
Cores 1280
ROP Units 48
TM Units 80
RayTracing Cores 0
Tensor Cores 0
Technology 16 nm
Memory type GDDR5 (Hynix)
Memory size 6 GB
Memory bus width 192 bits
PCI device bus 10 (0xA), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x1C06 (0x862C)
Revision ID 0xA1
Root device bus 0 (0x0), device 3 (0x3), function 1 (0x1)
Performance Level Base
Core clock 1569.0 MHz
Memory clock 4004.0 MHz
Performance Level Boost
Core clock 1784.5 MHz
Performance Level Current
Core clock 683.0 MHz
Memory clock 810.0 MHz
Driver version 27.21.14.6663
WDDM Model 2.7
Monitor 0
Model XG2401 SERIES (ViewSonic)
ID VSCBB31
Serial
Manufacturing Date Week 43, Year 2016
Size 24.0 inches
Max Resolution 1920 x 1080 @ 119 Hz
Horizontal Freq. Range 180-180 kHz
Vertical Freq. Range 48-146 Hz
Max Pixel Clock 340 MHz
Gamma Factor 2.2
Monitor 1
Model 22MP55 (LG Electronics (GoldStar))
ID GSM5A26
Serial
Manufacturing Date Week 7, Year 2014
Size 21.7 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-61 Hz
Max Pixel Clock 150 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8665
Config Mode LDN 0x4
Hardware Monitors
Processors
CPU Groups 1
Number of sockets 1
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- CCX 1
-- Core 3 (ID 4)
-- Thread 6 8
-- Thread 7 9
-- Core 4 (ID 5)
-- Thread 8 10
-- Thread 9 11
-- Core 5 (ID 6)
-- Thread 10 12
-- Thread 11 13
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
Codename Matisse
CPUID F.1.0
Technology 7 nm
Tjmax 95.0 �C
FID/VID Control yes
# of P-States 3
Package Type 0x2
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Power Unit 0.0
TDP/TJMAX 0x41005F
TCTL Offset 0x0
Thread dumps
CPU Thread 0
APIC ID 0
CPUID
CPU Thread 1
APIC ID 1
CPUID
CPU Thread 2
APIC ID 2
CPUID
CPU Thread 3
APIC ID 3
CPUID
CPU Thread 4
APIC ID 4
CPUID
CPU Thread 5
APIC ID 5
CPUID
CPU Thread 6
APIC ID 8
CPUID
CPU Thread 7
APIC ID 9
CPUID
CPU Thread 8
APIC ID 10
CPUID
CPU Thread 9
APIC ID 11
CPUID
CPU Thread 10
APIC ID 12
CPUID
CPU Thread 11
APIC ID 13
CPUID
Storage
Drive 0
Revision M0CR031
Serial 1644148229B7
Capacity 256.2 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 1
Revision M3CR032
Serial 2020E2A2A7A8
Capacity 931.5 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 2
Revision EMT03B6Q
Capacity 465.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 3
Capacity 28.6 GB
Type Removable
Bus Type USB (7)
Features
USB Devices
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090306
Revision A1
Codename GP106
TDP 120.0 W
Cores 1280
ROP Units 48
TM Units 80
RayTracing Cores 0
Tensor Cores 0
Technology 16 nm
Memory size 6 GB
Revision ID 0xA1
WDDM Model 2.7
Monitor 0
ID VSCBB31
Serial
Size 24.0 inches
Gamma Factor 2.2
Monitor 1
ID GSM5A26
Serial
Size 21.7 inches
Gamma Factor 2.2
ACPI
ACPI Tree
