Side panels and top panel off, front panel on. During the Heaven benchmark, highest graphic setting, AA x8, 3440x1440. My numbers were as follows:
ambient: 20 c
fans: 1,600 rpm
pump: 3,699 rpm (at about 60%)
Loop temp: 34 c
GPU: 53 c
CPU: 37 c
RTX 2080 TI,-slight overclock at 2055mhz. 8700K, not currently overclocked. 2x360 30mm rads, D5 pump. Pump--->rad--->rad--->CPU--->GPU--->res. 6 EK vardar fans, 1 stock NZXT case fan exhaust, NZXT H700 case.
Currently have all 6 rad fans pushing through radiator and out of case. I should have top pushing out, but front sucking ambient air in. That could be one reason for higher temps when panels are installed but even without panels on temperature is high, as seen in the above numbers.
FPS is fine. Ran Far Cry 5 benchmark as well, just to compare some numbers and FPS was higher than what a few others i saw have posted when on ultra settings at 3400x1440, averaging 108 FPS.
Thermal paste on GPU is Thermal Grizzly Kyronaut. Minus 8 pads on VRAM and such. I am fairly confident the thermal paste application is adequate, perhaps too much but that's better than too little right? I spent a lot of time making sure no bubbles were present in the loop. If any are hiding in the front rad at this point, I couldn't say.
From what I have read, loop temperature shouldn't be higher than 7-10 c over ambient, and GPU should be between 10-15 c above loop temperature, no more. I feel like my setup should cool everything better. Do I have too many bends? I am not sure what I am doing wrong. I know a lot of people go rad directly after component, but would it even matter in this case as equilibrium will eventually happen anyways and ya know....laws of physics and such. What is going on with these temps??
ambient: 20 c
fans: 1,600 rpm
Loop temp: 34 c
GPU: 53 c
CPU: 37 c
