ive noticed my msi gtx 1070 would make a low pitched buzz that is audiable from my case.
I realised it was my graphics card since the buzzing sound didn't play when I removed it from my case.
is this supposed to happen.i know coil whine is normal especially when the gpu is under load but this type of coil whine or buzz happens at the most random times.it dosent even have to be under load to have that sound.
https://vimeo.com/239332922
the sound kicks in at 0:09.and btw this was recorded in my bios so making sure nothing to do with drivers.
is this normal?if not is there a fix to it?it sounds different to typical coil whine plus its happens randomly and dosent need to be in load to do so.
and no its not coming from the gpu fans
