Recently my graphics card suddenly stopped displaying to my monitors while the PC was on, I tried the card in another build and it didn't work either, so I ordered a new card.
The new card arrived and I tried it, still no output, tried it in another build, output works completely as expected.
When I turn the PC on, all fans spin (even on graphics card) and all LEDs turn on, except on my mouse and keyboard which are connected to the mobo USB ports, my mouse blinks for half a second on power up but then only kees the sensor light, no LEDs (it has LEDs when plugged into another machine) and my keyboard has nothing. My mic (Elgato Wave 1) has it's mute button LED on, but the button LED does not turn red when clicked to indicate it is muted.
I also found some greasy substance right beside my motherboard heat sink, not sure if it relates.
I have tried seperate cables, mice, keyboards, monitors... all results are the exact same, I have also tried to start the PC without the GPU inside, USB ports still have the same issue.
Specs:
Old GPU - RX 470
New GPU - RTX 2060
CPU - AMD FX 6300
PSU - Cooler Master 550
Motherboard - MSI 970 Gaming
Specs:
Old GPU - RX 470
New GPU - RTX 2060
CPU - AMD FX 6300
