Question Graphical issue with GTX 1070 Ti
Christofer Julin
21
Hello. I keep having this issue with my graphics. Sometimes when I start the computer the screen keep flickering on/off until it reaches windows. Then it's either as normal or there are like corny sparks (like a tv-station without a signal). Today I received my first bluescreen. It happened while I was playing Fortnite and just as I started chrome while tabbed out, it sent me to the bluescreen. Also sometimes when I launch Counter-Strike (CS:GO), I can get a really low resolution in the game, and I cant even read the text. Either I have to change resolution in windows and back, or restarting the game for it to work. I always keep my drivers up to date and this has been going on for quite some time. I have updated the drivers for the graphic card many times, still the same issue. Thank you for your help :)
So, you are getting BSOD ? Are you using a FRESH installed copy of your OS ? What's the GPU TEMP value while gaming ? How old is your video card ?
Anyways, kindly provide PC specs, before we can troubleshoot your current issue..
-1. "Complete" system specs should ALWAYS be accompanied with any driver, hardware, or performance question. Do not post DXDiag reports as they contain a TON of useless information. Posting a DxDiag in place of a System Spec List tends to ward off potential members from helping you.
Please supply the following system details/information:
(Complete System Specs)
-CPU make and model# (clock speed/voltage, type of cooler, and "Core" temperature @ idle and load)
-Motherboard make & model# (include Bios version if graphics card is not recognized or you are having stability issues)
-RAM (amount, clock speed, model#/link of kit, configuration)
-Graphics card(s) make and model# (clock speed, voltage if modified, Driver version and GPU temp both @ idle and load)
-Power supply make,model#, "AND" age (note if using 110V or 220V A/C input)
-HDD/SSD configuration (ie: Raid setup/ back up/ OS drive/etc..)
-Case/Chasis make,model# (fan make, model#, and configuration if having thermal issues)
-Operating System (If using Windows note Framework and service pack version)
-Monitor make, model#, and resolution (If model# is unknown list resolution and refresh rate)
*If the unit is a "laptop" or "All-in-one" system you must note the make and model# of the unit. Be sure you are ALWAYS using the OEM/manufacturer's Driver updates for the unit.
*If "Crashing":
-Note the nature of the "crash" in detail, as there are several definitions for the word "crash".
*If "performance" related issue:
-Note the "exact" point in which the performance reduction occurred (ie: After Windows update, After Bios update, After Driver update, After thermal system shutdown, After Hardware change/upgrade etc...)
*For diagnostic purposes please disable the following:
-Any/all Antivirus/ Anti-malware software
-Any/all OSD monitoring software
-ALL overclocks outside of factory spec
Reactions: Kurtisdede
