Graphics card dies when I boost fan to 100%
BinyaminTsadik
I'm running a Radon HD 4800 card and the graphics mess up and the computer shuts down whenever i put the fan at 100% speed.
The problem is, that it now starts up at 100% speed again and it fails immediately.
I was able to bring it down from there by fluke, (after the graphics messed up but before the computer rebooted) but is there any solution to this problem?
Also, sometimes CCC.exe bugs out and won't let me change the fan speed unless I end task and start it up again.
rdc85
Try reseat the gpu clean the dust and make sure the GPU heatsink/fan is had proper contact.
For fan control u can download afterburner and set custom fan so it will never reach 100%... (set about 90% if the gpu runs hot u might wanna down clock a little)
But it only temporary solution, there is problems need to be solved...
BinyaminTsadik
I very much doubt that it has something to do with my power supply.
I'm running a Seasonic 600w Gold.
What happens is my graphics card bugs out. I get all kinds of white lines and a blurry picture and if I do manage to recover it says hardware malfunction.
