Graphics card help
IREFUSE
84
Okay so bought a GTX 770 card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130921
and was puting it in my motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
but it wasn't fitting into the PCI sloth because of the two pices of metal at the end where the DVI and HDMI ports are. If i tried to take off the metal parts would that void the warranty or affect the card. is there other way to slove this ?
Not sure if this helps but heres my built http://pcpartpicker.com/parts/partlist/
is it the two metal prongs at the bottom ? if so you need to slot them in to the tiny gap between metal. that will act like a track and should slide down easily into postion
any chance of a photo trying to install the motherboard because i dont quite understand how its getting stuck, and i wouldent recommend removing the metal bracket as it supports your gpu keeping it from falling
