[SOLVED] Graphics card ONLY FOR for hdmi output
phyle5
22
I want to use duel montior, but my card(mother board) has only 1 Hdmi slot. I am thinking to buy a used dirt cheap graphics card, just to get a hdmi out.
Is there anything I need to taken care of? Does the memory etc,,, matters?
My intention is to use 2 monitors. I am NOT a gamer.
PC:
4th gen i5, Asus H81m-K mother board, 8 gb Ram, standard Atx
Monitors:
Samsung 24 inch, and Dell 27 inch IPS display, Both are 1080 full HD. Both have 1 Hdmi and 1 vga inputs.
Would help to know what components you're working with.
What monitors are you using and what inputs do they have?
What are your full system specifications?
-Wolf sends
I have a i5 4th gen PC, Dell 27 IPS, and Samsung 24 inch, Both full HD 1080. Both have 1 hdmi and 1 VGA kind of port
My guess would be that the motherboard may not support simultaneous analog and digital outputs, but that's for the OP to respond to.
-Wolf sends
It sup
-Wolf sends
Nothing else on monitors other than power in.
Does dedicated Graphics card improve performance? I thought i5 have graphics processor built in , considering the fact that I have old machine 4th gen i5, and I do not opt for any gaming., ( but I do use adobe products.)
Depending on the graphics card and the applications being used, there can be some improvement. The suggested GT710 is more of a on-board graphics replacement. You wouldn't see much improvement.
-Wolf sends
Integrated graphics, even old versions, is perfectly adequate for desktop work and even HD movie viewing.
It is only for fast action gaming that one would need a discrete graphics card.
As perhaps an exception, some apps like photoshop can use a discrete graphics card for added function or performance enhancement.
Here is a link to FAQ on that:
https://helpx.adobe.com/photoshop/kb/photoshop-cc-gpu-card-faq.html
Reactions: phyle5
