Graphics problem
sharelord
4
Dear Community,
I have a gigabyte 945gzme-rh motherboard 1gig ddr2 ram, 160 gb hd, moniter LG 17inch CRT..Display onboard VGA..
My problem is that half of my display is not showing...no where not even in bios..Pls help..could it be a motherboard problem or a moniter.. Pls help me isolate the issue..
Thanking You..
Pulkit Chandra
You need to find out which component isn't working.
Either try a different monitor with your computer or try the monitor on a different computer.
If the built in GPU is the problem, replace it with an inexpensive video card.
OK.. i will tryout my spare graphics card.. Thank you sir for ur reply ...
