I have a Corsair 270r case with a ASRock H310M-HDV Motherboard with a GTX 1050ti and it just doesn’t seem to fit, i’m confident that the parts are compatible (this is my first build and i’m having severe troubles)
I'm getting confused here. Did you test your GPU on another system or have a PC technician look at your build?
It's nearly impossible for two GPUs to be faulty and since your monitor/cable is functioning and you reinstalled the drivers, I would suspect the motherboard itself.
Also, what is the brand and model of your PSU? +12v output current would help too.
Na man not yet, How much does it cost to hire someone? I honestly think it is my Motherboard because two GPU's, both faulty? I highly doubt it I might have to get a new MOBO but im not bothered to take everything apart
