Question GTX 1060 6GB making strange sound
eitvydasz1
Commendable
Mar 20, 2018
51
I found a video of almost the same sound I'm getting, Weird GPU sound .
It only appears when GPU is under load usually while playing games. I also experimented a bit with MSI Afterburned and found out that this noise appears when GPU fans are spinning on about 60-70% If I go below 60 or above 70 it spins without any strange noises. What do I do? What will happen if I can't fix it?
GIGABYTE NVIDIA GeForce GTX 1060 WINDFORCE OC 6GB GDDR5
Today I've removed GPU and found out that it's probably just plastic making this sound at some point.. If I put my case on the side the sound disappears. So I think there's nothing to worry about. I can live with that sound.
