Hi everyone,
I'm having an issue with my Lenovo Legion Y720 gaming laptop. The GTX 1060 6GB (Mobile) GPU is consistently running at very low core clock speeds — typically around 500–600MHz, only occasionally jumping to around 1200MHz under load. This is severely impacting gaming and performance across the board.
Thanks in advance.
System Specs:
- Laptop: Lenovo Legion Y720 (Model 80VR)
- GPU: NVIDIA GeForce GTX 1060 6GB (Mobile)
- CPU: Intel Core i7-7700HQ
- RAM: 16GB DDR4
- Storage: 256GB SSD + 1TB HDD
- OS: Windows 11 using TPM bypass method
- Drivers: NVIDIA 576.02
- BIOS Version: rolled back to 4GCN31WW
Diagnostics:
Using HWiNFO, I noticed that "Performance Limit - Power" is stuck on "Yes", even at idle, and only occasionally flickers to "No". Other performance limiters (thermal, voltage, utilization) are mostly off. GPU temperatures are staying in the mid-40s to mid-50s °C at idle and go up to mid-60s to max 70°C under load, so I don’t think this is thermal throttling. The battery is quite worn out at 63% of design capacity.Steps I’ve Tried:
- Clean reinstall of GPU drivers using DDU
- Rolled back BIOS since I read the latest bios version had issues
- Switched power plan to "High Performance" in Windows
- Verified NVIDIA Control Panel is set to "Prefer maximum performance"
- Cleaned laptop internals and fans.
- Changed thermal pads and paste
- Checked for any Lenovo Vantage power-saving settings (none found affecting GPU)
Questions:
- Could this be a power delivery issue with the internal VRM or motherboard?
- Is this a known issue with this model or GTX 1060 laptops in general?
- Is this a power supply / battery issue issue?
- Any suggestions for further troubleshooting?
Thanks in advance.
