GTX570 driver problems
rhayden
16
MOBO: ASRock Z68 EXTREME4 GEN3
GPU: ASUS ENGTX570 DCII/2DIS/1280MD5 GeForce GTX 570 (Fermi)
CPU: Intel Core i5-2500K
I just received all my parts and built my pc. It ran smoothly at first. Installed all the drivers okay. Then after a few hours of use, I received a message saying the graphics display drivers have stopped working unexpectedly. A few more error messages like that and my pc black screened and shut down. I reformatted my hdd. Now as soon as I install my graphics drivers, when it does the restart after, it shows artifacting on the windows login window and will crash and soon as it is opened windows. By crash I mean it will be logging in, and then my moniter says no input. All the lights are still on in my case, just no output at all. I can only log in on safe mode and I have uninstalled drivers, reinstalled them from numerous sources only to receive the same exact problem. As soon as I install those drivers, it can only start up in safe mode.
So my question is: How do I fix this!? mobo or gpu problem?
Thanks.
This doesn't look like a driver issue to me. No drivers would get approved if they cause that 😉. I had almost the exact same problem when I overclocked my GPU too high. Your PSU looks fine. Your GPU might be defective.
I always install my motherboard drivers first and they go smoothly. Then, without fail, I install the graphics drivers and the same thing happens.
I have taken out and put in my graphics card 3 times now. :??:
I think the card comes factory overclocked. Is there a way to underclock it to see if that is the problem? or how did you fix yours?
Well if you could get the NVIDIA control panel up you could reduce the clock speed down to stock but I'm not sure if you can manage that. I had to boot mine in safe mode to fix it but it was my custom OC. Your card is factory overclocked which means the manufacturer guarantees that it will run at the OC settings. If it doesn't then the card is defective.
Out of curiosity, how could you get nvidia control panel up? I can boot in safe mode.
That driver stopping error is not necessarily driver related all the time. I got the same message when I pushed GTX 460 overclock to maximum, which is obviously OC issue, not driver.
Having said that, my way of at least eliminating motherboard from the possible suspect in this situation is to remove the card, enable internal graphics in BIOS, connect the display cable to motherboard connector, and see if this setup can run. If it can, you now can eliminate the motherboard or CPU from the equation. In this case, most likely I would say either the graphics card is defected, or the power is not sufficient to the card. Are the PCI-E power cables connected to the card correctly? Like 6+6 or 8+6?
Yeah I tried the other slot and it did the same thing.
Yeah, i suspect it might be an OC issue because I did turn the settings on the card up slightly. I didn't think it would mess anything up (I wanted to see the difference between the small increase and factory). Is it ruined or is it salvageable? The power cables are connected correctly with a 6+8 config.
Ok so it started doing this from an overclock.
If you can get the driver installed in safe mode and drop the clocks it may only be the way to get it working, best to say how it happened firstly that way we dont have to go thru the other options of trying to figure out whats wrong.
I honestly didn't even think that was the issue because the problems didn't happen right after I did it. Until aicom said this happened when he Overclocked.
I just tried to install on safe mode and it said the PhysX system software Failed. The HD Audio Driver, and the 3d Vision driver all failed to install. But the Graphics Driver installed.
Can't find the Nvidia Control Panel anywhere.
Ok you are getting somewhere , right click the desktop is it in that menu?
Maybe worth a try , download msi afterburner and drop the clocks , make sure you check the box to apply settings on start up, see if that can get the card working.
I did. But I uninstalled drivers. Booted it regularly, and installed the drivers without allowing a restart. Then went to the control panel and it said: "NVIDIA Display Settings are not available. You are not currently using a display attached to an NVIDIA GPU."
