My specs
Asus Rog RTX 2080 TI 11GB OC
I7 9700K
Asus Rog Maximus XI Hero Mobo
2*8GB Gskill trident Ram
Acer predator 144hz Monitor
It has been 7-8 days since i built my brand new Gaming PC. I right away started gaming on it with games like GTA5,Far cry 5,PUBG,Resident evil etc and everything went well on ultra and mostly high settings with over 100 Fps
when i started doing some benchmark on my PC ,I was shocked to see that My GPU is failing (under-performing)
User benchmark test : Every component of my system performed well with over 70-80 percentile except my GPU .My Gpu was in 10th percentile when compared to others its rating was (162%) when average was around 200 %
Ungine valley and heaven benchmarks :- This is where i was shocked to see all these tests (custom,basic extreme) were showing shaded red colors and artifacts. I am not bothered to see the fps as all these tests were showing artifacts
3DMARK Time spy : I bought this software from steam and tested it .It gave me a GPU score of 6900 only.I googled and found in every other forum that 2080 TI owners are getting somewhere around 12000
All the above tests were done at STOCK settings only.I changed setting in my BIOS to xmp / defaults but still same Low scores and artifacts . I have MSI after burner and i check it and all the settings were at stock only like 0 memory clock and 0 boost clock for gpu.
Guys kindly tell me am i doing something wrong or is my GPU defective?? Do you suggest me to go for RMA or are there any troubleshooting steps that i can perform?? Kindly note that until now i did not find any problem in games.But its only 6-7 days since in built this PC
Any advice is appreciated
I7 9700K
