I'm curious what you guys think would be the best fan set-up for the Cooler Master HAF 912 case. I have 2x200mm fans and enough 120mm fans to fill every available fan slot, as well as a push/pull set-up on my Hyper 212+. I'm assuming that 2x120mm CM Blade Master fans would move a greater amount of air than 1x200mm CM Megaflow fan would. Currently I have 1x200mm fan on the front and 2x120mm fans on the top. Should I leave it the way it is, replace the 2x120mm fans for 1x200mm fan on the top, or get rid of the 200mm fans entirely? Will the difference in temp be noticeable at all? Thanks for the input.
