Hey guys, I'm stumped on this one. *Sometimes* Windows tells me that half my memory is hardware reserved, and reports my memory as 4GB (1.99GB usable). If this is going on in windows, BIOS tells me I only have 2GB installed. When there is no hardware reserve BIOS reads all 4GB, therefor this isn't a Windows thing. I'm wondering if there are any obvious explanations that I'm just not thinking of? Either way I'm about to run Memtest and I'll get back to you on that.
Specs:
i5 750
Biostar T5XE CFX+SLI
Crucial 2x2GB DDR3 1333 MHz CAS 9
8800 GTS 512mb
I know that my only real option is to run memtest, but I haven't had ANY memory related issues which I've always had, and I've killed a lot of RAM. Thanks.
[strike]Update: As I said below, each stick is completely clean when tested individually in the A1 socket. When I have both in the A1 and B1 sockets and I run Memtest, my computer reboots after a few seconds of testing. I'm currently testing a single stick, JUST in the B1 socket, and after a few minutes from the date this is edited, all is clear. Why would Memtest crash with 2 sticks installed? I've tested another 2x2GB kit of DDR2 about a month ago and it worked fine. I'm at a loss, and I can't find out what this "error" means on the Memtest website.[/strike]
Memtest is working now with all RAM installed on version 3.4.
SOLVED: For anyone with the same problem, I found another person online who said that the only way they were able to fix the problem was to reinstall windows and instead of just formatting the existing partition, to delete the partition and create a new one. This worked for me where formatting the existing partition didn't. Also some people solve the issue by enable memory mapping in their BIOS, and/or unchecking maximum memory and number of processors in MSconfig. To do the later hit the windows key and "r" to bring up the run prompt > now type in msconfig > once it comes up click the "Boot" tab > Now hit "advanced options" > untick the above mentioned items > restart. I hope this helps any one who stumbles upon this thread.
Specs:
i5 750
8800 GTS 512mb
