Question Half of Samsung's 43-inch monitor is darker
Aug 1, 2024
4
Half of Samsung's 43-inch smart monitor (M7) is darker. I tested the monitor settings and it didn't change anything. Is it a hardware or software problem?
Likely a hardware issue.
Monitor model?
Age?
If it is still under warranty, contact Samsung.
The Model is Samsung S43BM700UM. I bought it and using it for a year, I guess it's stillunder warranty for 6 month!
Do you think it gets worse if I use it in this way because it's not that bad while I'm using it, but I noticed it when i was draging a white window and realized it gets brighter to the left!
We can't contact directly to Samsung because I'm in Iran actually and the company I bought it they don't have this model anymore...! and I'm not sure if they accept it or not!​
As long as the packets are getting through the cable you aren't likely to see discoloration being the result so consistently. Looks like a bad or failing backlight or driver circuit. Perhaps something worse like delamination of a layer.
Could also just be a loose cable inside the monitor, but if it is under warranty, best to let Samsung take a crack at it.
Reactions: javad T
