So here we go.
I made a computer
Started out as
X570 ace Msi
Ryzen 5600 x
2070 super
Li Liam case
Trident g skill 3600 16 gb CL-18
Evga g5 supernova 1k watt psu
Fire cuda ssd 500gb
Samsung evo 970 500gb
Fully custome water cool.
It started to stutter in canes like micro stutter.
Symptoms are that the fps does not drop. But the percent utilization will go from 100 percent to 88 percent or so and stutter for a sec.
When this happens I notice a buzzing sound from my PSU every time it stutters. And the GPU usage goes down with it for a sec. FPS is fine.
So I take apart my custome cooled pc. And reseat everything and put on a reg AIO cooler. Because doing custome water cool takes hours. I wanted make sure it was working.
It still stutter.
My next step. New psu easy fix right? The psu made sounds when under load and made the GPU bog down. So I thought.
Got 2 new psu. 1k wat. One from Corsair mx edition
And another thermaltake.
Both did the cool wine noise. So weird. Stutter still there.
I swap out my mother board next. Same issue.
Got new ram… same issue.
Swap out my GPU. Same issue.
Swap out my cpu. Same issue
Swap out my fans. Same issue.
I even went as far as swapping out my monitor. And mouse and keyboard.
Made a bran new pc pretty much.
New system specs.
B550 strix a gaming asus
New 5600 x
7900 xtx gpu.
New ram g skrill same 3600 cl-18
New psu pystar 1k watt 80 gold
Ssd WD black s7 1tb
Pretty much a bran new pc.
- other things I did so you know.
Updates bios on 4 mother boards I tried. The last setup keep in mind isent everything I tried. It just what I have now.
I tried 3 different batteries.
4 different gpus
3 different set of ram. In different slots and order.
Obviously reinstalling windows and using ddu uninstalled for drivers.
Tried different monitors.
Different plugs. Thought it was my old house I was in because it was made in the 20’s
But just built a bran new house and still happens here.
The last thing I can think of is that I don’t have a windows key.
And one guy said that in a forum saying he had same issue I did and got window key. And it went away.
But all the research I have done shows that it does not matter.
But at this point it the only thing left to do. Other than go intel and see if this happens with a intel system.
One guy posted here with same issue. But never was resolved.
He had same symptoms of fps being fine but GPU utilization going down with stutter.
He never posted he had water mark for windows or not. But I have no idea. At this point I am about to give up.
I really don’t want to. But it rough 3 years of swapping out components every time a new game comes out. Just to have hopes I can fix it to play the newest game….
But I can’t atm
I made a computer
Started out as
X570 ace Msi
Ryzen 5600 x
2070 super
Li Liam case
Fire cuda ssd 500gb
It still stutter.
New system specs.
New 5600 x
7900 xtx gpu.
Ssd WD black s7 1tb
4 different gpus
But I can’t atm
