Question I'm having problems running some games and I can't figure out why ?
Jun 18, 2025
So I mostly play League of Legends and Marvel rivals, and for the past few months my League has been running really bad, like around 115 fps which I used to always get 144, and on Marvel Rivals it's anywhere between 90-110 on the lowest settings. I have messed with so many settings and tried stuff, I even just got a new GPU.
When im playing rivals my usages on my GPU are around 50% and my CPU around 80% nothing is over 60 degrees Celsius and in League its even lower, its a CPU usage game and it's never even over 30%
I have a i7-9700K and a GTX 5060 Ti 16GB.
Any help would be awesome :)
It sounds like the game may be more cpu bound than gpu.
What resolution are you playing at and what was the model of your previous gpu ?
I play at 1080p and my old gpu was a GTX 1070 that was previously refurbished
League of Legends is almost all cpu but the game is so old that my computer should be complete overkill for it and it barely uses up any of my cpu but still isnt able to get a solid fps
Sounds like a CPU bottleneck or background process issue. Try a clean Windows boot, check for background apps, and update BIOS/chipset drivers. Also, double-check power settings are set to High Performance.
Observe system performance using Task Manager and Resource Monitor.
You can also use Performance Monitor and Process Explorer (Microsoft, free) to observe system performance.
https://learn.microsoft.com/en-us/sysinternals/downloads/process-explorer
Use only one tool at a time and keep the tool window open and viewable so you can watch for what changes when performance falters.
It will take a bit a of trial and error to get a sense of each tool and the information that it provides.
The graphs can be quite helpful.
