[SOLVED] Having weird "xo" symbols on screen when graphics card in high usage, maybe hardver problem?
Ok, looked like it was, but was a bit difficult to read MSI AB with the artifacting.
What are your full system specs?
Is your GPU still under warranty? If so, I would suggest contacting the manufacturer for an RMA. That doesn't look good at all.
If it's not under warranty..... I'm not sure. Temps look fine on the core, but perhaps the VRAM is overheating?
the specs:
GPU: MSI RTX 2070 ARMOR 8GB
CPU: Intel i7-8700 3.2ghz
RAM: Corsair vengeance 16GB DDR4
MOBO: ASUS B360-G GAMING
PSU: Be quit! Pure power 11 600W
It is under warranty i bought it brand new 2 month ago.
