HDD not recognized by puter?.....HELP!!!
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.compaq (More info?)
Got myself an ebay special Compaq Presario 12XL300 Laptop minus hard drive.
I've tried to install 3 known good hard drives and none are recognized in
the bios and I get the message "Operating system not found" on boot. Any
suggestions besides staying away from ebay?
GMAN
yah set your drive to cable select , the CDROM is hogging the IDE
chain
>GMAN
In a laptop?
Personally, I'd suspect a bad motherboard I'd return it!
"Sharmon" <on@request.com> wrote in message
news:c7r380l1a4omaarrp27h4hlgpns7q2urop@4ax.com...
> chain
drive.
> >GMAN
Yes the CDROM and HDD are both IDE and should be cable select . This
would matter if it was only 1 IDE device
>In a laptop?
>> chain
>drive.
>> >GMAN
I've never even SEEN a jumper on a laptop hard drive or laptop cd drive.
news:arr4801g16fobu4q8rsi9bh69434qhkgeg@4ax.com...
> >In a laptop?
> >> chain
> >drive.
in
Any
> >> >GMAN
In my very limited experience on old laptops neither have I. Curious
though...what is the mode a laptop operates in...standard IDE Master/Slave, or
Cable Select? I'd guess IDE M/S, as that what I had to use when adding HDDs
and CDROMS to base expansion units for older laptops I have. (Not that any of
this has anything to do with the original poster's problem--I just wanted to
add a tidbit of interesting info to my "knowledge".
As for the original problem, try a CMOS reset, or could be a bad data cable.
Worse case, bad systemboard...
Dale
Dale
> Dale
> Dale
Looking just to the right of the 43 connector pins on a laptop drive
(Travelstar DADA-26480) are 4 pins, which can be selected with a jumper
for "Device0", "Device1", or "Cable Sel."...
My laptops came standard as "Device0" for the main C:\drive...
Willard :)
As I said most (not all) Compaqs are cable select and if you set it
to 0 or 1 it will not work with the CDROM in
>> Dale
>> Dale
>Willard :)
Verdict is in, it was a bad motherboard, hard drive was set to CS, bios was
set to auto. Thanks for the help.
GMAN
"DavidG35" <DavidG35@NOSPAMcox.net> wrote in message
news:thlgc.55088$U83.40455@fed1read03...
drive.
> GMAN
