[SOLVED] HDR VS SDR for in-game performance FPS/Input Lag.
RagedAPE
214
26
18,640
So I turned off HDR in display settings on windows and went to SDR since someone said SDR is better for gaming and SDR has less input lag, plus produces more Frames per second.
Can anyone confirm this and maybe give me some details in regards to speed and performance between the two?
My monitor is Aorus F125F-Ek 240hz IPS if this helps at 1080p
Kind regards,
Ape
sdr has more fps as it needs less resources to display it (lower image quality)
input lag...hmm from pc side there shouldnt be any difference, that should be monitor/tv image processing issue if u see input lag there
