I recently destroyed my H100 corsair liquid cooler a product i was totally satisfied with except for a small design flaw in the molex connection leads (they broke off and ground was not marked) and i was forced to get a replacement of which i chose an H80 to save 10 dollars. (Yes it is one of THOSE stories). Upon trying to install the H80 i was required to flip the airflow of my system. I had a 200mm side fan and a 120 mm back fan draw air in while my top two 200mm fans were used as exhaust pulling the air over the radiator as it was expelled back into the room. now because of the difference in radiator size i was required to take my top 200 mm fans and flip them making them bring air in while taking my back fan and turning it into an exhaust fan with the radiator mounted on it.. i put in a second fan to sandwich the radiator between two exhaust fans both 120mm. I was also required to remove my side fan which cooled my graphics card and general system. This changed my boot up tempature according to my bios to 50c from 35ish a BIG jump considering this is when the system is turned on. However exactly sure how my system determains the tempature as i do not have any user servicable tempature probes so my data could be inaccurate but it is VERY worrisome to me what would you the community thing about the tempature and do i need to do something to fix this?
