Help backtrack 5 vmware
G
Guest
Guest
backtrack cant recognize my wifi adapter and some terminall commands like airmong-ng do not work
my adapter is intell r 4965agn
forget to tell u its backtrack VMware
Any virtualisation software can only use USB wireless network cards as physical devices, all other types of wireless card are seen as virtual ethernet devices and can only be seen as a wireless device by the host and not by the guest operating system. So if you want to run BackTrack in VMWare or Virtualbox and have full wireless capabilities, make sure you are using a USB device.
http://www.backtrack-linux.org/wiki/index.php/FAQ#Why_cant_BackTrack_use_wireless_card_.E2.80.9CX.E2.80.9D_inside_VMWare_or_Virtualbox_.3F
ok thanks for your help ill buy an alfa adapter
but there are another staff.....
some commands do not work (airmong-ng) in the terminal
wt can i do for this>
Latest posts
